090322-1258 EST
chris:
Any idea what these "Had 2 meters" really measured? I assume they were supposed to measure power, but did not, or were falsified somehow. Clearly the Amprobes measure current.
Ass't Lord-High Commish:
I am not going to buy somebody's expensive capacitor to prove it won't reduce an electric bill.
The data of my earlier post of 090321-1201 EST is adequate proof that power factor correction does not change the amount of "real" power used. I made an adequate change and that is enough proof.
Admidtedly I gave the salesman that I talked to at the show a hard time, but he is ignorant and is typical of the type that will say anything to make a sale.
He may not know that what he is selling is a fraud, but I really suspect he knows it is a fraud, and that is why he is unwilling to discuss what really happens relative to power factor correction.
Unfortunately his customers are also ignorant. In far too many areas customers fall for testimonials as proof that an item does what is claimed. These customers do not do any independent evaluation of the claims, and unfortunately may not have the ability to do so.
One of the arguments of this salesman was that the PF correction improved the motor efficiency. Total nonsense other than if it changed the voltage at the motor terminals and shifted the motor to a more efficient operating point. Even if the shift was in this direction the improved efficiency would be minuscule. If the test were run so the motor terminal voltage was unchanged and in both cases a pure sine wave voltage was applied, then there would be NO change in efficiency. If precisely the same voltage is applied to a motor with and without a shunt capacitor across the terminals, then there is no change to the excitation of the motor nor internal to the motor and therefore there can be no change to the characteristics of the motor, including its efficiency.
