Has anyone had an hvac condensate pump keep tripping on gfci but not non-gfci receptacle?
What is tripping, the breaker or the GFCI receptacle?
That means there is a problem with the condensate pump. The only way around that is to get a direct wired condensate and I am not sure they make one-- I think they make them 240v but not sure about 120v.Yes the pump trips the gfci rec. but would then run fine with a non-gfci rec.
