Question; I have a 208v delta to 230/400 Y xformer supplying a machine. Only one VFD motor in the machine is 400/3p/3w (.9kva). The rest of the components are 1ph.230 w/neutral;(one leg to neutral). I want to remove all of the components off of the supply transformer and just supply the VFD with a smaller xformer, and then supply the machine with 120/208Y. Does a component that is 230v -(one leg to neutral) have the ability to be supplied with 208v/1p (2 legs) if they are rated at 208/230?
I have never even thought about this before until working on European equipment. The intent is to maximize the efficiency of the xformer as it is using a 25kva xformer for 5.5kva equipment. The 6kva xformer will be cheaper and cooler. Also it consumes a large footprint currently.
Any help would be appreciated.
