I have an Engineer that wants me to feed a 75 KVA XFMR 480/208-120v with 3 #8's and a 40 amp breaker, the secondary has 3/0 and 225 MCB. I understand NEC 450.3(B) Table requires that the primary OCP be sized as the percentage of XFMR-rated Current which would be 250% for primary and secondary protection, I know that I can go down to 125% but he wants me to go lower then the rated primary of the XFMR which is 90 amps. The current load is minimal at this time, and the primary feeder will be increased later when other loads are added.
Will this be code compliant with 450.3?
