We have 2400V feeder line feeding 2 motor-driven pumps (also 2.4KV). The line side fuse popped on one phase and we replaced and everything worked; just a day or two later on the same feeder another fuse at different phase popped. We meged the line side feeder to see if we got a ground, it checked out good; also the load side line to the motor, and it also checked out good. now we suspect there might be something in the motor, so that's our next step to check, but my questions here is:
how come the fuses for each motor (we have 2 motors) are good but the feeder fuse popped first? I think it should be the other way round, cause the feeder line fuse should be rated higher than that of the motor right?
what do you think the cause for this is?
Thanks
Thanks
