I think we are essentially in the middle of the following argument:
? Person One says, ?I submit that the grass is green.?
? Person Two replies, ?No, you are wrong. The sky is blue.?
Let me try to resolve the issue in the following manner:
1. If someone wanted to buy carpet for the living room, and if the sales agent asked them for the area of the room, could they give an answer in units of acres? Well, yes they could. But that is not the usual unit of measure used in this application.
2. If someone asked you how far it is to the nearest grocery store, could you give an answer in units of inches? Well, yes you could. But that is not the usual unit of measure used in this application.
3. If you were considering buying a hot tub, and if you asked the sales agent how much water is needed to fill the tub, could the agent give an answer in units of milliliters? Well, yes he could. But that is not the usual unit of measure used in this application.
4. If someone asked me how fast energy is being exchanged between two inductive machines, could I give an answer in units of Joules per second? Well, yes I could. But that is not the usual unit of measure used in this application.
Regarding item 4, if I were to choose to give the answer in that unit of measure, it would be incumbent upon me, for the sake of avoiding future confusion, to mention that this number of Joules per second is being exchanged at a phase angle of 90 degrees from the number Joules per second that is being supplied to resistive loads. It would certainly be simpler if I gave the answer in units of VAR. That way, I would have less explaining to do.
