vinster888
- Nature Coast of Florida
those boxes suck. almost as much as non twisters.
Same here. I've broken many tan boxes with a poorly-aimed swing of the hammer, but the blues are resilient.never had a need to buy the fancy fiberglass ones when the cheap plastic ones are there.
Blue boxes are inexpensive, lightweight and most importantly non conductive, therefore, superior!
You use wire that has plastic insulation and it's wrapped in a plastic sheath. Why would you want to put it into a metal enclosure? They have the fire rating so what's the problem? Is it one of those "I've always done it this way" things?
Only a hack would install NM in a metal box :grin:
PS. They also now make/sell power tools without cords!!
Try this one time for me. Next time you are making up wires, simply line them up evenly, all the same length, hold them together tightly and start the wingnut. Once it takes a good bite aftera couple of twists, keep going until the wires start twisting around themselves and you can't get it nmuch tighter. Then unscrew the nut and look at the ends. They will be twisted almost as tight as they would be if you used sidecutters.
That's nothing! Yesterday, I saw a power cord without a tool!PS. They also now make/sell power tools without cords!!
I resemble that remark! grin
Seriously, I use them. Why not? :-?
I'll agree with that. The wirenut alone cannot twist the wires as much as the use of pliers can. The discussion here, though, is whether that alone makes a real-world difference.When I have tryed, a wire nut will not twist 3 #12's solids as tight as the would be if twisted first.
Sometimes, I twist, and sometimes, I don't. for example, I won't bother with a pair of 14's, but I probably would with three or more #12's. Either way, the connection stays cool.
Or worse, hang a ceiling fan from a round one.Oh no....you're not one of those guys that uses those awful Allied boxes that crack and the thread holes strip out?
If he used a 3M tan/red I dont think this would have happened. Those Ideal wirenuts suck bigtime. You can crankem down hard as you want and they will loosen up as you pack them into the box. I've never had a 3M do that.
The problem in the OP has nothing to do with the wire connector and everything to do with faulty installation. And those don't look like Ideal wing nuts - they look like GB wing nuts. The Ideal wing nuts don't have the angled wings like the GB's do.
As opposed to the Carlon boxes purchased at the supply house?
Look up when you say that!!That's because you're a small giant, Larry.
Ok - I'm wrong with the wirenut brand. But those wires look kinda twisted to me... :roll:
As should be obvious by now, I must challenge that statement. I haven't heard a real reason blue = hack yet.
A lousy chef can ruin a great filet mignon, and a great chef can do wonders with a lowly hamburger patty.
I'll take the creation of an artist with chalk and crayons over that of an ape with oils and acrylics any day.
I'm just saying that I don't think the kind of wirenut has anything to do with this failure. It was definitely loose enough to cause arcing.
