What kind of above ground pool is this? If 42" deep or deeper, you wire to the same rules as in ground pools. See definition in 680.2:
Permanently Installed Swimming, Wading, Immersion, and Therapeutic Pools. Those that are constructed in the ground or partially in the ground, and all others capable of holding water in a depth greater than 1.0 m (42 in.), and all pools installed inside of a building, regardless of water depth, whether or not served by electrical circuits of any nature.
Next, see 680.21 for your pump motor. Even if it is cord-and-plug connected, the branch circuit must be in conduit and must have an insulated grounding wire. There is an exception for circuits ran within a building, but once outside you need conduit and a green copper EGC sized #12 or larger.
There are no special requirements for the pool heater circuit. But the unit must be connected to the bonding grid.
