DM2-Inc
- Houston, Texas
Does the NEC limit the maximum difference in wire size, of the same circuit, at a screw terminal? I was told many years ago that it was 2 wire sizes, but I've never found it in the NEC.
We have a situation where the power supply (24 VDC, 75 Amps) is designed for connecting a 4 AWG wire. Some of the devices this power supply is powering are 1,000 to 2,000 feet of cable away. To minimize the voltage drop, I want to connect a 4 AWG wire to the power supply and run about 2 feet to a power distribution block that will allow me to increase the cable size to 350 kcmil at which point It needs to be run about 50ft to a marshaling cabinet. At the marshaling cabinet will go to another power distribution block and get distributed to a series of fuses that provide the power to the field devices. The wire out of the fuse will range from 4 AWG to 8 AWG. The load in the field varies from 1 Amp to 7 Amps. My voltage drop calculations start at 20.1 VDC (85% of the power supply rating...a code requirement). Because I need to have a voltage at the device no less than 18 VDC, I need the huge cable.
I'm also not sure that short circuit calculations wouldn't govern this either.
