nightmare
- MD and currently overseas
I am required to mitigate what is widely thought to be an impending major electrical disaster. 4 4" PVC pipes in concrete with 4 A's in one, 4 B's in the next and so on.
They are 500's and there is one extra 500 per pipe as a spare. There was no earth ground when I arrived so I have since pulled a 1/0 through each pipe. I did this expecting to phase the work and provide ABCNG in each pipe. I have less than perfect megger results on a couple of the feeds which might cause a problem for my original plan. I am, therefore, exploring my options.
Is it bad/dangerous/code violation to put one phase per pipe and, if so, please explain? :-?
The only explanation I have gotten so far is in three parts:
- that's the way I learned it
- they will blow up if they ever pass through a metallic ring of any kind
- you will really hurt someone if they ever cut into the single phase accidentally
