what are my options for changing out a old 30 sub panel, with 10-3 uf no ground wire as the feeder ( all 3 wires are insulated ) & a metal water pipe between the house & the pump house. the load in the pump house is a 240 volt pump & 120 volt light & gfci plug. it would be almost impossible to run a new feeder.
the old panel has all the grounding & grounded conductors tied together & bonded to the well casing.
option 1 hook up new panel like the old one.
option 2 seperate the grounding & neutral & use the water pipe as the egc.
option 3 install a plastic nipple in the water pipe at the pump house.
this is were i need some expert advice, i don't like option 1 due to the possible hazard of parallel grounding & neutral. i don't see a hazard with option 2 ?. option 3 i'm not a plumber
thanks for the help
thanks for the help
