I think the question is if this is one branch circuit or not. If it is only one then you are good to go. If the panel has more spaces then one then a rod is needed. 250.32 (A) exeption
I think in my opinion this would be coverd in the exeption. I have a iilistrated NEC handbook by the same people of the NEC and it shows what J rae is speaking of. Because of this I think that was the intent of the rule.
The breaker is serving as a disconnect and GFCI protection.
If you do consider this a feeder, was it wired per NEC 680.25 (insulated equipment ground)?
To me, if the tub is the only thing connect to this panel, its a branch circuit.
however the NEC Handbook Illistrates the point exactly as I have made my point and allows it. It illistrates a single breaker in a panel on a remote building. The GFCI is a single breaker.
I realize people do make mistakes. This illustration could be one.
If you pulled the GFCI out and put in a switch then it would be a Branch circuit as you state. and installed the GFCI in the panel ahead. this would be ok?
It's interesting on how the iilustrator went out of their way to show a panel and breaker or was their thinking it is a switch?
I would say yes, as the hot tub meets the definition of a structure.
Chris
Chris do you mean that the hot tub meets the definition of a structure or do you mean that the free standing deck meets the definition of a structure?
What would be the difference between hot tub disconnect and a/c disconnect. No rod required for a/c.
