If you view NEC 810 it will become clear...
810.1 Scope. This article covers antenna systems for radio
and television receiving equipment, amateur radio transmitting
and receiving equipment, and certain features of transmitter
safety. This article covers antennas such as multielement,
vertical rod, and dish, and also covers the wiring
and cabling that connects them to equipment. This article
does not cover equipment and antennas used for coupling
carrier current to power line conductors.
NEC 810.21(F) Electrode. The grounding conductor shall be connected
as required in (F)(1) through (F)(3).
(1) In Buildings or Structures with an Intersystem Bonding
Termination. If the building or structure served has an
intersystem bonding termination, the grounding conductor
shall be connected to the intersystem bonding termination.
(2) In Buildings or Structures with Grounding Means.
If the building or structure served has no intersystem
bonding termination, the grounding conductor shall be connected
to the nearest accessible location on the following:
(1) The building or structure grounding electrode system
as covered in 250.50
(2) The grounded interior metal water piping systems,
within 1.52 m (5 ft) from its point of entrance to the
building, as covered in 250.52
(3) The power service accessible means external to the
building, as covered in 250.94
(4) The metallic power service raceway
(5) The service equipment enclosure, or
(6) The grounding electrode conductor or the grounding
electrode conductor metal enclosures
A bonding device intended to provide a termination
point for the grounding conductor (intersystem bonding)
shall not interfere with the opening of an equipment enclosure.
A bonding device shall be mounted on non-removable
parts. A bonding device shall not be mounted on a door or
cover even if the door or cover is non-removable.
(3) In Buildings or Structures Without Intersystem
Bonding Termination or Grounding Means. If the building
or structure served has no intersystem bonding termination
or grounding means, as described in 810.21(F)(1).
(1) To any one of the individual electrodes described in
250.52; or
(2) If the building or structure served has no grounding
means, as described in 810.21(F)(1) or (F)(2), to an
effectively grounded metal structure.
(G) Inside or Outside Building. The grounding conductor
shall be permitted to be run either inside or outside the
building.
(H) Size. The grounding conductor shall not be smaller
than 10 AWG copper, 8 AWG aluminum, or 17 AWG
copper-clad steel or bronze.
(I) Common Ground. A single grounding conductor shall
be permitted for both protective and operating purposes.
(J) Bonding of Electrodes. A bonding jumper not smaller
than 6 AWG copper or equivalent shall be connected between
the radio and television equipment grounding electrode
and the power grounding electrode system at the
building or structure served where separate electrodes are
used.
(K) Electrode Connection. Connections to grounding
electrodes shall comply with 250.70.
Basically you are dealing with 810 and not 820 for most of your question.
