2wheelinusa
Anyone have any tricks when wiring buildings with interior metal ribbed siding? I have noticed many times you cannot fasten the 4" box directly to the siding because there is not enough room to offset the conduit coming out of the box before it hits the rib. Even when the ribs are 12" centers there isn't enough room. I have ran conduit from opposite sides out of the box across the ribs and 'floated' the box and that seemed to work well, but I'm not sure if that is code or not. Other ways would be to put a wood block behind the box for a spacer, use offset fittings, or maybe use a box extension and run the conduit into the extension, but all of those are kind of a pain. Any suggestions?
