Hello, I'm going to be responsible to set up a rather large 'seasonal' lighting display in a garden park. I will be using an 400 amp 600 volt service which will be feeding 600 to 120/208 volt transformers scattered though-out the site.
These transformers will feed distribution panels mounted inside of wooden enclosures that will keep them dry. The panel enclosures will have receptacles to plug in cords that will feed the 120 volt circuits.
The question I have is reguarding the cords. I would like to use 5-wire cabtire and have three circuits on each cord. The male ends are going to be three phase twist lock. My question is what to use on the female end where the christmas lights will plug in? The outlets will be out in the elements and should be code approved for this use.
Am I going to have to have something custom built?
Thanks
Thanks
