kris davis
- Irvine KY
We got a call to check out a Waste Water Plant we renovated 4 years ago. The U.V. system is burning bulbs and ballast up faster than normal. The U.V. tech said they need at least 270 volts at thier ballast but they our only getting 268-270 volts. When you shut the power off the the U.V. unit the voltage goes up to 271-273 volts. Each unit has a 480v4w 100 amp feed to them.
Also I started and stopped a 100hp pump and the voltage only dropped .5 volts
