For Fifteen minutes, you can bring out the big floor buffer turn it on and
hear the Cap turn off... :grin:
Radio Shack has some peg board books of little devices that can be built.
get two phone (older) handsets and place a 9 volt battery inline on one, and get to talk through wires...
Break out a rheostat (NOUN: A continuously variable electrical resistor used to regulate current. ) put that on line to something and play with the it...
Break out an motor (kept cold) and have them ohm and take reading in a preventative maintain routuine. Megger well... you can explain that
slowly heat a wire with current on it, noting results.( U can use a single blower on it)
off | stop| on... wire that and then add momentary switch.
Maybe, maybe not...
Get a magnet, gauss meter and wire, explain Gauss Law, the old magnet under paper with metal flakes, always a crowd pleaser.
You could go into orbital body's and the law of attraction
Here that link is corny but its will explain it if you follow the links.
search all of newtons laws: But wait you say I don't need no Newton... oh
Newton's law of gravitation resembles Coulomb's law of electrical forces, which is used to calculate the magnitude of electrical force between two charged bodies. Both are inverse-square laws, in which force is inversely proportional to the square of the distance between the bodies. Coulomb's Law has the product of two charges in place of the product of the masses, and the electrostatic constant in place of the gravitational constant.
Newton
F is the magnitude of the gravitational force between the two point masses,
G is the gravitational constant,
m1 is the mass of the first point mass,
m2 is the mass of the second point mass, and
r is the distance between the two point masses.
verses
Coulomb's
Q1 represents the quantity of charge on object 1 (in Coulombs),
Q2 represents the quantity of charge on object 2 (in Coulombs),
and d represents the distance of separation between the two objects (in meters). The symbol k is a proportionality constant known as the Coulomb's law constant. The value of this constant is dependent upon the medium that the charged objects are immersed in.
Pure water experiment with Salts and and lemons and organges... citrus, measure for...
Explain polorized Glasses! Explain sun light as it goes forward.
Explain the Electromagic Spectrum...
Explain why a crystal displays a rainbow, back to Newton.
explain or experiment with Newton's Laws and the Electrical Force
Chapter three of electrical forces
