As I understand it, it is current flow that creates magnetic lines of force. In reading a textbook on DC electric motors, I come across this statement Re. speed control: "DC motors can be operated below base speed by reducing the amount of voltage applied to the armature and above base speed by reducing the field current". Why would not current be the determining factor in both cases? Is there some way that voltage itself impacts the magnetic field that I am missing here? I know P=IE. Isn't magnetic flux always be in direct proportion to my Power?
Its the sum of various quantites that make magnetic lines of force. It will always be ratio problem in A DC system its more dramatic result of this propotional math equation.
If a reduction of voltage in DC then what happen to the current number in the eqaution. Yes there less over all push as that voltage is applied.
Well probably the biggest things that you might be missing is how the two types of motors are wound!
In general: AC motors are mainly wound to the Outside, and DC on the armature (the Shaft). So where the real work is accomplished from the rotation, DC generally give better torque output from their own design,
the voltage is applied to the shaft. In AC it has to work the field that is on outside to make the inside shaft rotate.
You have to remember that DC sum of power is at some Line be it 12 V or 480v while ohm's law is still appliable, comparing that DC Flat line to 480v 3ph AC
its the sum of the AC power pulsing that creats the RMS the useable/work power. I can't recall seeing any graphs on DC line summary with voltage or current detracting from a DC line graph of its power.
You could think of it this way, you know that the power is based on the Sum
of voltage and current in either cause, something has to give. With AC you'd probably burn up the motor with higher current their not built for that excess
application where DC motors are. DC are just more bigger in all respects.
