In the jurisdictions where you may work or inspect I would like to know if a connection to a Concrete Encased Electrode is required.
This seems to be a "no brainer" on new construction but Jurisdictions around where I work have conflicting opinions when it comes to a building addition where there is re-bar installed in the footing and the service equipment is unaltered.
Some will say that the fact that it is only an addition to an existing structure has nothing to do with the fact that the CEE is "present" and there must be an attachment to it. Others say that if the existing service is not altered that no connection to the CEE is required.
I would appreciate any opinions on this as long as your justification is based in code language and not opinion.
Thanks, Pete
Thanks, Pete
