PhaseShift
We have a 480V 20A breaker that is currently feeding a combination motor starter located in the field (unsure of FLA rating at this point) We need to feed another combination motor starter in the field that will be added. The question is weather we can parallel this second combination motor starter off of the same breaker?
I am under the assumption that is is possible as long a the two seperate circuis off of this breaker have a cable rated at or above the 20A breaker. We will also need to verify that the breaker is large enough to supply the sum of the 2 motor loads plus 25% of the largest motor load. Are these the only two things that need to be taken into consideration?
