Celtic,
First off I like the Handle. Secondly, I suppose I should have been clearer. These are run horizontally, and instead of routing them above the corridor ceilings and then into each unit, all the units on one half of the building are run thought the units on that half of the building. So the unit closest to the electric closet has 6 or 7 feeders running through it, then they drop off as you move away from the closet. The second to last haveing two feeder though it.
I do agree that other systems (plumbing, HVAC, etc.) run through dwelling units they do not supply, especially vertical runs, but those are not electrical, so I really do not care to comment on them. Also, when those system run through those units, depending on the system, they are sometimes provided with a fire rated enclosure and these feeders are not. Those systems typically are not metered individually, so there is no incentive for a tenant to cut into them to steal services.
I guess my biggest beef is that the conductors can be tapped. I know they are MC but with the high cost of electrical service these days I've have seen some crazy things done to steal electric. And I assure you given the time and tools, MC cable can be broken open and tapped. My second concern would be when the person who owns or rents dwelling unit one (with the six feeders passing) decides he wants to renovate his condo or rental and he tears into the walls and ceiling, he may be directly handling the service feeders of those other units, and performing demo operations (which are not usually done with the greatest of care) may cause damage to the cables. I know that one is a reach, but stranger things have happened. If the wiring method were pipe and wire or bus duct, or some other well protected means I would let it go, but its MC.
So I still have the same question. Am I missing something in the NEC or is there another building code that prohibits this install? If not great, but if so it would help my argument for the building owner to have those feeds run down the corridors. If it were my building I would want to be able to get to those feeders in the future without having to put out another tenant, or better yet shutting down half the units on the floor to work in unit one.
Thank for your input.
