hunt4679
- Perry, Ohio
I am looking to find out if the code has a maximum distance for any type of conduit run before you need to install a pull box (pull point).
My rule of thumb is every 100 feet or every 270 degrees in bends I'll set a box. Why make it hard on yourself? Boxes are cheap.
Mr. Wizard....which of your "rules of thumb" is actual "code" ?
If that's his personal rule and it works for him that's fine. As noted it's not an NEC requirement. Depending on the number of conduits and their respective sizes, the elimination of a pull box can save quite a bit of money (think of parallel 4" conduits)
For small stuff I would agree with the Wizard boxes can be cheap insurance to make the job a little easier.
