longbeach1125
- long beach NY
I always wondered this.
Thanks
Joe Sweeney
Thanks
Joe Sweeney
so if its 2 legs of power why is it called single phase?
Thanks
Joe Sweeney
In keeping with the voltages outlined in the 220.5(A) and elsewhere in the NEC, I would refrain from using the 110/220 volt description, 120/240 is more accurate.
As Bob touched on there is no simple answer.
Joe,
That's its own tough question. We should have a thread where everybody goes to their panel and measures the voltage on the main lugs and posts them here.
I'm sure that's already been done, so if you know which thread, please post it because I"d be interested in seeing it.
Your personal opinion meets the current U.S. standard nominal system voltage of 120/240.I reading my post again I would reiterate that this is more of a personal opinion. Certainly if a post contains the 110/220 voltage we'll know what the person is talking about.
Nah. What bugs me is the 110/240 type notation.That was my only real point. The question was posted in the NEC section of the forum and the NEC outlines in Article 220 and elsewhere the nominal voltages that we use every day. Maybe I'm just being a little too anal today. :roll:
Thanks
Joe Sweeney
No. It can also be obtained from using two phases. Some transformers are connected line-line on the primary side.The single 120/240 system is obtained from just one phase of a three phase system,it all done at the transformer at the pole.
gary
Not all the time... My single phased power comes from a delta primary from two phases... (3-wires alternately taking two each block.)The single 120/240 system is obtained from just one phase of a three phase system,it all done at the transformer at the pole.
gary
What you really have is 1 phase that has a center tap that is grounded. Hope that helps
