Ok ..70E says we have to use voltage rated gloves on anything above 50V. Working in a chemical plant we constantly are required to work on live 120 VAC controls ciruits. Before you jump me about shutting it off, keep in mind we have a DCS system that controls the entire plant and shutting it down to replace a bad device is not an option (so we lift the wire at the terminal strip). So back to the voltage rated gloves, most of the live work is on small wire and I keep getting a lot of complaints about the gloves, no very user friendly. Does any one have a recommendation on the best gloves to use, glove that offer manual dexterity?
