brian john
- Leesburg, VA
Does anyone know if there is a UL requirement or any standards on hardware that should be utilized in terminating connections in switchboards?
No the grade of the bolts utilized.
I have and have had all the recommended torque requirements. We have a job were the engineer after the fact is stating that only Grade 5 hardware can be utilized for electrical termination made in the field and of course he is slandering our work based on this.
Have you asked him for the documents supporting his claim? Surely, he must have something to back it up besides his mouth....
We contacted DuPont and that wax had gone out of production in 1952 or 1954. They wrote a letter stating this and noting that the car waxes they marketed today were far superior to any of their 1950 products. The inspector was dumbfounded.
I certainly believe 1/2 of that.We had a spec that called for all painted surfaces to be waxed with two coats of a DuPont type car wax, the year was 1983 (or there around). We could not locate this wax anywhere, The inspector refused to accept any other type of wax and told us no other contractor had ever questioned the wax, they followed the specs.
I don't know of any "standards", but according to Burndy's Connector Theory 2007 publication, galvanized steel don't even make the recommended hardware list for combinations of copper-copper, copper-aluminum, and aluminum-aluminum bolted connections. Only silicon bronze, stainless steel, and aluminum hardware make the list. GS hardware does make the list for copper or aluminum to steel connections, though, but no grade of hardware is specified.... We have a job were the engineer after the fact is stating that only Grade 5 hardware can be utilized for electrical termination made in the field and of course he is slandering our work based on this.
http://portal.fciconnect.com/res/en/pdffiles/brochures/BURNDY+Connector+Theory+-+2007.pdfI've searched for a copy of the publication on the fci burndy website to no avail. Also, its file size is too large to attach here, so if you PM me with your email address I'll send it to you as an attachment.
