Hendrix
- New England
This cable can be directly burried but can't be run inside. So......How would it attach to an electrical panel inside the home :-?
That's what I was thinking. I have a EC who came out of a manufactured home's disconnect, under ground and into the sub panel inside the home. I didn't think that it was compliant.You can run it to the meter socket underground, from meter socket to inside the house
you need to change to a compliant method.
Just be sure to take a good look at the cable as many of them have multiple markings. URD/USE is possible, although that doesn't help you with interior wiring, as is USE/RHW which would be acceptable.
http://www.southwire.com/products/RHHRHWUSEOEM.htm
