http://hyperphysics.phy-astr.gsu.edu/hbase/electric/shock.html
This one contains an old chart that many may recognize:
http://pchem.scs.uiuc.edu/pchemlab/electric.htm
Remember that there are (2) variables, voltage and resistance. Quite often voltage is constant given a certain situation but resistance can vary widely as there are many factors that affect resistance.
Then it's good old ohms law that takes over, I= E/R With voltage constant raise the resistance and current goes down, current goes up when the resistance is decreased. Raise the voltage with a given resistance current goes up and down with lower voltage.
Then what path the current takes through the body.
Essentially you don't want to mess which getting an shock because the result are uncertain, anything for OH BOY I shouldn?t have done that, shocked on your butt or knocked off of a ladder where you get injured in the fall, burned, or.......
