How do you handle a case where a feeder circuit is protected by a feeder breaker however the feeder terminates into another breaker?
For instance a 125A breaker is protecting a feeder that terminates into an 100A receptacle breaker. Technically a #1 should be used on this circuit in order to be protected by the 125A breaker. However since the feeder circuit terminates into a 100A breaker can a #2 be used and still protect this feeder by this downstream 100A breaker?
Is this a version of the tap rule or some other rule?
