Sierrasparky
- USA
- Electrician ,contractor
a colleague and I have a disagreement.
We would like to know that if you have an existing bathroom under remodel and are changing out the heat lamps in the ceiling and installing a heat ,vent, light.. The original circuit is 15 amp and powers the vanity light, GFCI outlet, heat lamps , and leaves the bath to power lighting in the bedroom ,and hallway.
The question is do you need to run a new circuit for the heat,vent ,light because it uses about 80% of the rating of the circuit?
For me it is the preferred method and there is no rehab code here.
Thanks
Thanks
