Hello every one,
I am new in this forum and hope i can get some answers regarding my question.
Recently I have repaired a damaged starter motor from Caterpillar engine.The motor it self was OK and only the coil which is connecting the starter to the fly wheel was burned.That was the only replaced part in the motor but nothing to do with the direction of rotation of the motor.The starter was working til the coil burn out.After replacing the coil and test the starter I found that the motor is not turning in proper direction which really twist my brain.This type of motors the reversing is possible only by changing the polarity of either the armature or the field but not both.
Does any body have an idea what could cause this motor to change the direction of rotation without changing any connections?!?
Regards,
Stoy@n
Regards,
Stoy@n
