Does this trasnformer have a Y-Y solidly grounded Primary and Secondary?
I don't see any grounding of the neutral point in the diagram. It shows the primary neutral connected to the secondary neutral, but it's labeled 'neutral disconnect.'
In most uses, the primary's neutral point should be left floating, and connected as a Delta load, although the POCO doesn't seem to leave it floating in their installations.
I'd read the instruction book as recommended on the label. If you don't have it, contact Westinghouse.
