Federal Pacific Panels
chris1971
Usa
I always tell my customers that these panels are dangerous and need to be replaced. Does anyone have a good website, link or information that I could look at and possibly share with customers?
macmikeman
I tell my customers that there is possibly problems with those panels, and then I take them to a link about the issues. I am reluctant to make definite statements about products until this is proven beyond any doubt that they are in fact absolutely dangerous, not just possibly some are dangerous....
Rewire
I just tell customers that FP panels should be replaced and tell them to google fedreral pacific. I also tell them replacement breakers start at $25.00 .
I used to use the soft sell on FPE. Tell the customer that it should be changed but doesn't mean it will catch fire tonight, there are 10's of 1000's of these serving and there is not a fire every night etc etc. I would then tell them to google it. (This scenario was if I was in the house for something else and noticed they had an FPE).
Than one day about 2 years ago something happened to make me step up my rhetoric. We were doing miscellaneous things in this home that had an FPE panel. One of things was to change out a broken receptacle. My journeyman was taking it out when it essentially crumbled in his hands. Well this caused a H to N short (yes I know we shouldn't have been working hot but that is not what this thread is about). When these wires shorted they arced so bad that something in the box actually caught fire- my Jman told me he had to blow out the flame. The breaker held.
From that day forward I always tell people that they are taking their safety and the safety of their families in their hands every day they leave that panel up.
cal1947
waldorf,md
electrician
electrician
there was a article in the realstate section of are paper a person ask that same question and the resonce was that one homeowner that bought a house the homeowners ins. co. would not ins. the property unless they had a lic. con. change th e service.
rcarroll
I inspected several panel change-outs this year due to insurance letters.
zappy
CA.
I've noticed that about FP breakers. You try and turn them off, and you have to be a freakin body builder.
don_resqcapt19
Illinois
retired electrician
That can happen with any breaker and the fact that it can happen is one of the reasons that the code now requires AFCIs in dwelling units.
When there is an accidental fault like this you have no idea of how good of connection was made nor any idea of how much current was flowing. It does not take a lot of current to shoot of a part of the wire or device and have that part hot enough to ignite something in the box.
Ohmy
Atlanta, GA
It possibly has problems? All panels could "possibly" have problems. The FP panel is a known defective product with a well documented history of failure. IMO, changing an FP is a "must fix." Besides, I would be flat embarrest if another contractor found out that my customers have FP panels in their house.
How would you like it if your mechanic causally mentions that you care has the old firestone tires or some other major defect after years of using him to work on that car. He says "its not big deal, I mean, your car is running now right?"
Ohmy
Atlanta, GA
My guys bring burned up devices and FP panels back to the shop all the time. This is much more common than you think. I've replaced two FP panels where the fire company had to come out to the house to put out the fire.
don_resqcapt19
Illinois
retired electrician
I am not saying faults that cause fires don't happen, I am saying they can happen with any breaker. Very few faults are bolted faults and flow enough current to operate the breaker in its instantaneous trip range. That is not a problem with the breaker....it is just the nature of many faults that limit the current to the point that the breaker does not open quickly.
macmikeman
Ohmy, about 1/2 of the structures built on Oahu built before the 70's had FPE stablock panels, commercial and residential. The community has not by and large suffered from this firestorm you are referring to. There may well be some documented cases of fire due to those defective breakers, not near to the degree you are attempting to sell. I find bad circuit breakers in older panels of all brands. I didn't run out and get a swine flu vaccination either just cause it happens to be getting lots of press right now.
rodneee
federal pacific electric co. out of newark nj makers of the STAB-LOK breaker. they were considered state of the art at the time. currently they are known as "change on sight breakers". after reading these posts i had to find some in the warehouse. i got a few (maybe a hundred) that have been sentenced to life on the shelf without the possibility of installation. the one aging prisoner is a two pole 50 1960's vintage with white painted on/off and red painted 50's (no raised lettering). he is an old bird as he is both copper and aluminum rated.
