tonyou812
- North New Jersey
I went on a site visit today that was a proposed basement reno. While I was there talking with the Homeowner he told me that when he had his sump pump installed he had a problem with it and when the tech came out to check it out they found that there was current present in the water. If you put your hand in the water you could feel the electricity. And he was told that he needed an electrician to come an fix the problem.
So he called an ec and he said that the origional water bond was missing due to pex being installed, which broke the bond. So A new water bond was installed (#6, 100 amp service) and the problem went away.
I guess one could say that the problem was solved but it didnt satisfiy me. My feeling is that the water bond shouldnt be installed to acually do work but instead be there as a fail safe....I think that there is a more serious underlying problem and the ec only put a band aid on it. I put my amp meter on it and it only read 1.8 amps (granted there were no real loads on the house save for a few lights).When I pushed the float switch on the sump the reading jumped to 6.8 amps. I didnt spend a whole lot of time investigating due to the fact that I didnt have the job yet but I was curious anyway.
What do you guys think about it...? The service is an old Square DQO from the 70's. And the HO wasnt living there yet so there wasnt really a big load on the home.
