- Bremerton, Washington
I am helping with the electrical at my church which will have a good bit of audio equipment, mixers and amps. We installed a 24 ckt small feeder panel with isolated ground - OK go easy on me here - it makes sense with audio equipment to keep all the audio gear equipment grounds at the same potenial.
There is a very sharp audio guy to who I mentioned that I would like to install a SPD (A Leviton panel mount) at the feeder panel and he had done some research on this, saying that the MOVs in a typical SPD can conduct or break down causing noise and problems in the audio equipment.
He mentioned this mfg
http://www.surgex.com/
They make a series SPD
http://www.surgex.com/products/iControl.html
There are a lot of white papers on the surgex website, seems like there is some justification to the series SPD theorey for branch circuits.
What I know about audio systems is that its important to get the grounding right to eliminate hum and noise.
Could I install a Leviton panel SPD at the feeder panel and be OK?
Would the SPD ground go to the panel ground or isolated ground?
