Most recessed lights provide their own access. What kind of lights are they? Fluorescents or standard cans?We had some recessed lights in gyp. ceiling and contractor said there is no access panel...
Absolutely!They are compact fluorescent downlight...so if we have to install (2) can lights in gyp. board ceiling - 8' apart using emt conduit, should we install conduit before gyp. ceiling in?
Can you point out for me specific section of building code address this? Who is responsible for this?
Absolutely!
Recessed fixtured don't require above-ceiling access after installation because the housing can be removed from the frame, and the J-box has a cover that faces the hole.
