A/A Fuel GTX
- WI & AZ
- Electrician
Can anyone tell me what that metal strip that comes with these boxes is supposed to used for? I can't even take a guess as to how many I've thrown away.......
they keep it from being pushed into the wall
You have to pull it out and insert the metal strip in the groove on the side of the box. This prevents the far side of the box from being push in. The metal bracket should bump the sheetrock on the opposite side of the wall keeping it steady.
I think the "Phantom Stud" is a much more effective way to firm up the box. The metal strip seems kinda cheesey.
I use the metal strip. Why make more work than necessary? And how can you say it's cheesy when you don't even know what it is?
Ok, I actually took the time to look at the 4G on the opposite side of the nails. I see where the strip plugs in and I'll give it a try on my next house. Scott likes the finished result so it can't be all that bad. Thanks for the enlightenment...........seriously
