Is there a formula used to detirmine how much DC voltage need to convert to a specific AC voltage?
(Example: A generator is putting out XX VDC into an inverter producing XXX VAC)
or is it just a matter of adding a step-up or step-down transformer after the inverter?
While this is true up to a point, economics is the most important factor. It is more expensive and the least efficient to go from lower voltage to a higher voltage.With modern electronic circuits, this is a product design engineering decision. An DC voltage can be electronically converted to any AC voltage.
But still, lots of budget 12V DC to 120V AC units are available. So to some extent it depends on what you got and what you need.
