Question
1) Is the ground wire pulled from POCO transformer to the meter or only phase(s) and the neutral are pulled from the POCO transformer to the meter and then ground is derived from local water main?
2) If 1) is true, why not ground is pulled from the POCO transformer where neutral is grounded at the transformer?
Both will work though, but in later case the ground will be direct rather than thru earth as in case 1.
My general question is, in practice how grounding scheme is achieved; from POCO to customer Panel point.
