Hi, I am working on a battery sizing for a substation. I have a whole lot of outdoor SF6 breakers and gang operated disconnect switches. The control power for breakers and switches is 125VDC. I consider the breaker sequence operation for peak load calcuations and all the relays associated with breakers for continuous and peak operation (i.e. 1 minute operation per IEEE485)
My question is with regards to the switches, these switches are killers, I mean they take about 15amp to operate. Infact I do not need them to operate on fault, they will be operated for maintnenace as required. So, considering their use should I include them either in my continuous or peak load calculations? Either way my battery size will go up...
any advise or discussion is really appreciated
thanks
thanks
