K8MHZ
- Electrician
If an electric heater is rated at 1500 watts and is entirely inside the room it is intended for and is measured to draw the correct current to provide 1500 watts does anything else matter?
I don't see how it is possible for a 500 dollar heater rated a 1500 watts to provide any more heat than a 17 dollar heater rated at 1500 watts.
Am I missing something or are the expensive electric heaters a scam?
FWIW, I do know users of the expensive heaters that claim huge savings on their other heating source, primarily propane.
I am a big fan of the cheap heaters because for a fraction of the initial expense and the same cost to operate, I can pretty much shut the furnace down, even at 20 degrees or less, by just heating the room the T-stat is in.
I wonder if the folks that bought the expensive heaters ever really gave the cheaper ones a chance.
