mattsilkwood
- missouri
I was at a plant a few days ago to replace a bunch of thermistats with a programable type.
They were all supposed to be 24vac controls. I had to pull new wire from the units because I needed the common for my new thermistats and they had two wire cable pulled.
So I open up the first unit and I find a 480/120 control xformer. What they had done was take 120v through the thermistat and back to the starter for this unit.
This paticular thermistat ran two units so I go open the other unit and find the exact same thing.
After tracing down the old cable I find that they have spliced both hots together then through the thermistat and back out to the starter on each unit.
Niether of the control xformers were bonded.
My question is how was it possible to tie both of these xformers together like this and not pop the fuse on the secondary on one or the other?
This is a drawing of what I found.
