When they seen there mistake why didn't they just turn the box sideways
Because they didn't have the foresight to check for obstructions when they used a drywall saw to cut the wall.
I am surprised most of you have not seen this lately. This is the new box support method approved in the '08 NEC. Soon to be the most popular method in bathrooms and kitchens.
Why not just use an old work data ring and avoid having to cut the back out of the box?
Think equipment grounding conductor , and NOW it makes sense
A payback is in order. Drill out the upper tank on the toilet and run a few branch circuits thru it....
I make my first cuts horizontally, because I'm more likely to run into a stud than I am to hit a pipe run.
And just how do you do that? Did you buy the X-ray glasses they sell in the back of comic books?..........
That's the worst thing about residential. You see some crap all around, but almost every homeowner has a brother in law, nephew out of rehab or a leaf raker who "can do that for you". ... But he was probably cheap, so it's OK.
