I am uncomfortable with a residential fire/security I am about to take over.
Currently there is a Napco Gemini P1632 installed with system sensor 2W-ATB installed on the two wire smoke loop.
Napco states their panel is compatible with that model. System Sensor does not. It is not a listed as a compatible device on System Sensors side.
I feel that is good enough reason to not use them together, also the power draw would probably be more than what the circuit is rated for.
It's installed and supposedly working(I did not yet test them, the owner is closing on the house today) but I don't like messing around with UL issues with fire devices.
To make matters worse, there are no other smoke alarms.
I have submitted a proposal to swap out the smokes in question and add wireless interconnected smokes. This is an existing construction that just had $500,000 worth of work, so cutting holes to add anything is out of the question.
What are your thoughts????????
