091104-0605 EST
Nyle Watt:
You have to be far more specific.
What do you mean by "--- GFCI comes on occasionally ---"? Do you mean it occasionally trips? If so, then is the tripping associated with power applied to the heater, or turned off, or both, or at totally random times uncorrelated with the on-off cycle of the heater?
What is the nominal supply voltage for your area? The load current of the heater?
Model, manufacturer, and date of manufacture of the GFCI?
What are some likely ways in this installation for leakage current to occur from the heater (all of the load on the GFCI)?
Describe what is a Nuheat system?
Any other information that might correlate with the problem?
