We have a Radio antenna and 12VDC PV module on the same pole. Can the coaxial cable from the antenna and the DC cables from the PV module run in the same raceway (pole) down into the pole mounted enclosure?
Closest thing I see that says "no" is Art. 820.44(C), however, this is not entering a building. The system is a stand alone system on a pole. If not permitted, exposed conduit will work fine.
Thanks for any input!
