1:1 transformer/reply
a 1:1 transformer or isolation transformer is one where the turns ratio of primary to secondary windings is unity ,it is used in lighting distribution designs where the graph of a earth current fault is very sharp,if sensed by the substation's main breaker's protective relays will trip and everything will go down,to avoid this the isolation transformer is used as the current pull reflected back to the windings will cause only those sub-circuit breakers to be affected for those of us in the field ,many times if a supply leg goes to ground ,like a motor leg ,the fault is so sudden that the line and load protection for the motor may not trip but the substation's main breaker may trip.As this lighting design use 277 volt to earth on their ballasts the isolation transformer is used,good discrimination design will also be required
a 110volt contactor and photocell is to be used with 480v to110v control transformer, delta to star with grounded neutral transformer is to be used
