Electron_Sam78
- Palm Bay, FL
What all constitutes a separate building or structure which would fall under section 250.32? For an example I have a service disconnect/ distribution CB panel which feeds two subpanels about 450 feeet and 600 feet away through underground runs. Subpanel B which is a stand alone panel (mounted on boards) feeds a pavillion's lights and receptacles. Subpanel A is inside a bathroom building. There is also a lift station fed from Subpanel A about 50 feet from the bathroom building. Would all these, including the lift station, be considered separtate buildings and structuresand require a ground rod (or electrode) at each specific location?
