Hi,
I'd like to see how some of you interpret 250.122(F) in terms of whether the section is outlawing the use of the conduit as the means of equipment grounding for parallel conduit runs, or if it's stating that if you choose to utilize conductors (wires) then its requirements apply.
For example if I had twenty feet of two parallel 2" rigid steel conduits with four conductors (3-phases, 1-neutral) in each from main panel to sub-panel, can I still rely on the conduits as the equipment conductors?
Thanks,
Creig
Thanks,
Creig
