Houston
- I will give you a hint. TX
I always thought code said you need to ground rods. Where does it say you have to have 2 to count as a grounding electrode. The only kinda referance i found was 250.56. I always drive a second ground rod when I do a panel change, but I dont think its required. unless 25 ohms or less.
