BTW, I was responding to jghrist. And I follow what you were saying about the sign.Never mind. I see you were talking about the real component.
Never hurts to be correct the error in case a newbie reads it later. Clarity is a good thing. It also keeps us from being sloppy (like my first post in the thread)....At this point I wish I hadn't said anything.
BTW, I was responding to jghrist. And I follow what you were saying about the sign.Never hurts to be correct the error in case a newbie reads it later. Clarity is a good thing. It also keeps us from being sloppy (like my first post in the thread).
Originally Posted by dkarst
Sorry but the value you arrived at above for the combined leg is incorrect, you cannot multiply the phase current by 1.73 to get line current in this unbalanced delta case. The correct value is 2.72 A
I would really appreciate if you could elaborate on this.
Consider a purely resistive heater circuit; 1 - 600W between phases 1 & 2 and 1 ? 900W between phases 2 & 3; for a total of 1500W.
Since we are just having fun at this point:Except that Post #8 really was wrong. I'm not sure why the angles get screwed up in the math of dividing P by V vectorially. It might require getting into complex conjugates. I don't want to go there.
It is actually two unbalanced single-phase loads (or were you disputing the 1.73 part?)...Since you do not have a 3 phase load the 1.73 factor does not come into play. This is an unbalanced single phase load.
I would agree if addition to the missing load between 1-3, leg #2 was disconnected from the power source but this is not the case.
There is a difference when discussing the source and the load. A source can play multiple roles, a defined load does not.I would say this is unbalanced 3phase circuit
Of course, but watch the grouping/calc order: 1500w/480v/1.73=1.8A...and if we are not truing figure out current thru leg #2 only at the given moment, then I believe this is correct formula for leg #2: Leg#2=1500w/480v*1.73=1.8A
Original quote by mivey:
I2 = I23 - I12
or 1500w/(480v*1.73)=1.8A
It is just a sign thing. One current was headed towards the node and one was headed away from the node so we subtracted one to get the sum.Do parden if this is a stupid question because I've been out of school for 25 years and never worked as an engineer:
Shouldn't the 2 vectors be added together instead?
The magnitude of the current in the common phase wire has got to match the magnitude of the vector sum of the currents in the first two legs.
Sherlock
The 1.8 was for a "what if was not an open delta but a closed delta" scenario. Not the same as what the OP asked.Now I'm confused, I agree with your post a few back (and mine ~15 back) that the current in common (#2) leg is 2.72A, not 1.8 A ? You're not saying it is 1.8A, correct?
I hope not. I can barely see my screen for the White-Out.Thank you, I missed the "what if" and thought we had a new answer to the OP question...
Using the direction conventions given in #18 (important to keep the signs consistent), and the method from #25:What would be your calculations for the current in the leg #2 if we assume: V12=480V @ 90?, V23=480V @ -30?, V31=480V @ 210??
Your sign conventions suck...JMHSO.Using the direction conventions ... (important to keep the signs consistent) ...
